Are Xtd paddle clutches any good? Been looking at them on eBay and they seem a bit cheap
Ha! well done on tax evasionI hope so because mine arrived a couple of days ago. Got mine for ÂŁ155 (didn't bother with the lightened flywheel) and arrived within a week, didn't even get hit with any import duty
You live n learn :yes: As T-Mac said, is it actually a problem then? Someone else posted elsewhere that it is more the friction disc/material than the pressure plate/cover although I also would have thought more clamping pressure=less slip potential. Would be nice to get definitive answer if only to help future potential purchasers make a more informed decision. My own driving style/usage of my car probably is not the best test bed in terms of pushing the clutch to its limits as I am a 58 yr old "steady Eddie" :rofl:They're apparently OEM replacement Exedy covers, i.e they dont have any greater clamping force than stock. The model / part numbers match up apparently, the guys in the states have done the necessary checks. It's not just hearsay.
Done quite a few miles now with mine and don't have an issue with it, yes if I try to drive it like I did with OEM then it judders as it certainly doesn't "slip" easily when setting off at low revs for a smooth take off. However, give it a few beans and you get the most satisfying launch :yes: I adjusted my driving style to suit and bingo!! smiles all round. Remember it is not an OEM standard clutch, not similar at all, but has light pedal action, grips really well and for me the whole combo (inc the flywheel) was a billy bargain. I have to say though that a few thousand road miles is not a conclusive result for testing of this clutch so who knows what may happen further down the line. Would I fit another to a different 5? Most definitely if it had substantial more power than standard :thumb-up:Thanks, I'll see how it goes but it sounds like I may want to spend a few more pennies next time.
Well that's set my mind at ease a bit so thanks. Time to get 500 miles under my belt so I can get my turbo fitted up
