i've finally got my car to start and idle reasonably well on the EV14's (525cc) but still not perfect esp when cold (seems to need a lot more PW than i would have expected).
was thinking maybe the opening (dead / latency etc) time might be worth a fiddle, at the moment it's still as per the stock injectors (1.00ms)
i'm a bit confused by what i've read on the internets plus what it says on my data sheet from the Fuel Injector Clinic.
First up, the data sheet shows 'injector voltage offset' - is that the same as opening time? so at 45psi (ok for mk1?) i have 1.25ms at 12v and 0.95 for 14v.
So for 13.2v i'm looking at around 1.16ms?
However, info out there disagrees...
Injector Dynamics (EV14's) have this chart for 725cc's
so around 0.92ms at 13.2v but with my injectors being smaller size, this would imply even smaller opening times.
From the group buy thread, i found these settings
650cc EV14's
650cc EV14's
So i'm guessing my injector voltage offset is not the same as opening time and i should be looking at setting my opening time to around 0.55ms. What does this actually do - what will happen in cranking, and what changes can i expect to my VE table etc?
