Creaking Under Braking
1.1K views 11 replies 6 participants last post by  SlideyFivey
Hi,
I need a little help please, my mk2 has for some time now been creaking under braking, sometimes it seems to go away for a little while but it always comes back.
It seems to creak regularly ie every rotation of the wheel and continues as you get slower and slower until eventually coming to a halt the creaks last longer and longer if you know what I mean.
I've bounced the suspension when stationary and there is no creak from the suspension, I'm at a loss and getting really annoyed with it now.
Does anyone know of a fix or have any idea what's going on there?
Any help appreciated.
Matt
#4 ·
could be a sticking caliper putting strain on the suspension and a bush making the creaking noise. maybe antiroll bar bushes or the bushes in the drop links, moving as the weight goes forward. have a poke around. use a lever to find movement in the bushes and check the brake in that corner. grease the sliders with red rubber grease or ceratek brake grease, something like that. normal grease doesn't cut the mustard due to the heat.
spose it could be the top mount moving around if it's old. have a good hunt around.
#10 ·
Fitted the new Polybush anti roll bar bushes but not had any joy sadly, it is still creaking. Worth doing the job though, old ones (original set I think on an '04 reg) were squashed and the holes in the middle were about 5mm larger than they should have been.
The hunt continues so when I find out where the issue lies I'll give an update then :)
