37K views 409 replies 33 participants last post by  Shadowraven
#53 ·
Looking forward to seeing your exhaust.
I made a side exit for one of the r5's I had, sounded like a tractor! Only had a midbox tho.
Alex you just going single rear box, no mid?
#55 · (Edited by Moderator)
2" is a bit on the small side. Needs to be 2.5" ideally, will cost you spool time and HP.
Really, my DP had a 2 inch flange at the base so went off that, would be 2 inch and straight through to a can at the back???
I was under the impression of keeping the gases moving faster.
#56 ·
Cheers.
I was thinking of going side exit, then realised I would have to go around the chasis rails and decided it would be to close.
Just single rear box and a pipe.
#57 ·
Bigger is better with turbo exhausts. I like ak's old side exit exhaust.
I'm going 2.5" with manual exhaust flap and single rear box, and if I can find one cheap enough a mid box.
#58 ·
Ruddy fuck, better send all this shit back then
Why not just go 3inch then?
#59 ·
I had 2.5" stuff, and 3" can be trickier routing around things.
And I'm doing mine on super tight budget so it's been whatever I can get for free/cheap
#60 ·
2.5 inch it is then.
#63 ·
I sold my mx5parts system as knew it would be a restriction.
Between us we should really do a DIY guide to all this.
I will do something for this exhausts when I make it. Photos and links to parts, that kind of thing.
#65 · (Edited by Moderator)
#67 ·
Nice Work, im making mine out of mild steel. Just phoned up to change my Order to 2.5 inch, but it had already been dispatched.
Bloody hell a grand, mines costing me ÂŁ150 to make. Probably another ÂŁ50 to do it in stainless.
#69 ·
Iv gone for aluminiumised steel, I was going to do as you did and weld stainless with normal wire and gas. But then thought if the welds are going to rust, I might as well just do it in a coated mild steel.
I do have a TIG welder here, which is my little brothers but it's bloody 3 phase.
#71 ·
Yeah I know, couldn't justify doing that on a stainless system.
#73 ·
#74 ·
I need to practice more with my welder my welds are getting strong but look a mess. Only used it twice need more scrap. Il love to make my own exhaust. Side exit is a no go i forgot the chasis rails stuck out so low id loose clearance. Out the back or out the side of rear bumper maybe :)
#75 · (Edited by Moderator)
Yeah im no pro either, just bought a MIG when I had a 1983 Mini as it was the logical thing to do. Good skill to have when you need to make a bracket up, or when you look at one of your sills.
Just sent all my wrong sized exhaust metal work back, better part of ÂŁ30 at the post office :censor:
