1 - 1 of 1 Posts
Just fitted one of these to my drivers door. Had a bit of a job getting all the bolt holes to line up with the door but eventually got it in and the window gos up and down as it should.
I can't seem to get the window adjusted correctly, it sits tilted down to the left so the windows catches on the hood when you open and close the door and doesn't sit properly in the front channel. According to rods manual to sort this out involves slackening the three screw the hold the glass in place and retightening once it's where it should be. This doesn't seem to work! i tried three or four times and putting loads of pressure on the glass I could get it to sit flush in the front rail but once it went up and down it ended up as it was before
Has anyone else had problems getting these to work properly or is there a secret way of adjusting these that I'm missing?
1 - 1 of 1 Posts
