While I've Got The Engine Out...
1.8K views 4 replies 4 participants last post by  Rocky eunos
#1 · (Edited by Moderator)
So despite this being a '97 1.8 I've been experiencing the dreaded crank wobble more commonly seen on the short nose 1.6.
I've managed to get my hands on a donor bottom end and pulled the crankshaft which is off to be measured and ground if needed.
My question is, while I've got the motor out, is there anything else I should be taking the time to do other than giving it a good clean?
If you are removing pistons Hone the bores (to clean any carbon and take the shiny surface off the bores. New crank key (woodruff key) and oil seals front and rear.Clean the oil pickup pipe particularily the mesh pickup piece.You would have to check the clutch while its out.And waterpump at least
#4 ·
Cheers for the advice guys, my engine doesn't guzzle oil so think I'll check the compression and then make a call on the piston rings.
Any take on oil pump? I'd rather not as they're pretty expensive but I'm not sure what the lifespan is and would rather not have to take the bottom end apart again anytime soon.
