1 - 13 of 13 Posts
I pondered for months about how to improve my car and finally in March booked in with Blink motorsport for their stage 1 cylinder head package (head work, cams, ECU & tune) but due to them having to close down I am in need of recommendations.
I'm not into forced induction, so I'm set on maximising the NA potential.
I am searching for a tuner who can do a similar job on my MK1, ideally within 2 hours of Stoke on Trent.
At a push, I would learn how to remove the head myself, and post it off to someone who knows what they're doing, then refit it, along with a new ME221 ECU, then take it to a local rolling road.
Does anyone have any suggestions?
Automotive tire Bicycle part Rim Automotive wheel system Machine
B4 spending big money on head work...how about lightweight flywheel and diff ratio change..
I read somewhere that as my car is a 1995 s-special import it has a lighter flywheel as stock. I am happy to be corrected on this. It certainly seems more lively than a 1993 1.8 UK MK1 I owned some years back.
was going to ask what engine....
but you answered this here....
is it easier to get another head modified then fit - the car is not off the road so can be enjoyed....
plenty of engines around, I have a 1.8 head etc. in my shed....
as to flywheel, theres a slight difference in weights but not massive, a proper lightwieght flywheel from TTV etc will be around 4kg and ~ half of the standard 'lighter item....
also, if you use a 1.6 type flywheel & clutch that has a lower MOI as a smaller diameter clutch with a 'flat' flywheel compared to the 1.8 design.
^^ don't get drawn into needing a 1.8 clutch for higher power as modern 'competition' clutches from Helix etc. will easily handle NA power & torque (y)
as to specialists to undertake headwork, theres plenty or real competition engine builders around, a quick google search will show a few near Stoke that can do real headwork as opposed to the basic blueprint you were going for;)
Thanks for the advice Rich.
Perhaps get a used head (as Rich says, there's plenty around, I've got a spare too) and give Basset Down a call, especially now that Skuzzle is working there. I have the Blink stage 1 setup (the very first one, in fact), with an MS2, and a lightweight flywheel (5kg), and a full Racing Beat exhaust. it's a big performance increase.
For the record Rich, Blink are (were) very much a real competition engine builder, BRSCC champions too. Their 'optimised' heads were painstakingly developed on a flow bench, with a lot of shaping behind the valves, de-shrouding, 3 angle valve seats etc. Not a basic blueprint :)
I wonder if the actual design spec for the Blink heads will be passed on (sold) to another company so their development work is not lost.
Not as close as you want but.. Basset Down.
Is that true of the basic performance packages? I don't think so... I think it was a extensive blueprint/refurb combined with very well researched valve seat angles and a compression bump. Certainly no deshrouding going on..
I would ask na8cgee for the name of the company he licensed his headwork development to. Having a head (CNC) ported will be a lot more expensive then the old Blink options, but maybe they can do a skim and valve angle job for you to na8cgee's specs?
It sounds like you're referring to their 1.6 race series heads, limited to valve seat angles and a skim by regulations. Mine was the first 1.8 they did, for a chap called Gary who had a Westfield. As documented on this thread:
There certainly was deshrouding on mine, and reshaping the chambers behind the valves. I bought his engine complete in 2014 when he went FI. So I don't know about the subsequent packages Blink offered. I assumed they were the same as mine, although looking at that thread again, it seems Gary paid extra for the deshrouding.
Standard head inlet:
Blink head:
Discussion Starter · #13 ·
I had read na8cgee epic thread about his head development. I didn’t realise he had licensed his specs. I shall ask him.
1 - 13 of 13 Posts
