Wheels In Motion Spring Setup: Take 2
1946 Views 23 Replies 6 Participants Last post by  AndyBRG
I have been running the Koni Sport kit for several months and was unhappy with the springs provided (Over 10k Miles), i looked around at my options and gave Tony (WIM) a buzz.
He offered me his WIM springs at a discounted rate and would fit and align for free, this was done on thursday and i have covered a shade over 300 miles across every type of road going.
I am running on the middle perch all round and the rebound is full soft on the front and middle on the rear and FM rear mounts.
The alignment is WIM fast road, which i had before (or a version of at least).
Before fitting there was a few doubts whether they would be ok as the Koni springs are wider, but they went on without issue and there is no chatter etc.
Initial impressions
The ride height is much lower on the back, the car is flat on the middle perch with no massive rake, and the front is about 5mm higher (than Konis).
The ride is less crashy over bumps and more able to cope with speed humps (bar a few silly ones in stratford upon avon).
Body roll in corners seems a good compromise and very similar to the Konis, but it is by no means flat.
The only "negative" observation so far is that the car (especially the back end) seem a bit more bouncy than OEM or the Konis, but nothing that puts me off using them.
Over the next few weeks i will update this thread and have a play around with the Koni rebound settings once i have done a few more miles.
Any specific questions, please ask.
One week on
I ran the above setup (rebound is full soft on the front and middle on the rear) to work and back until mid week and overall i was very happy with the ride, far less crashy over bumps and mounds in the road. Body roll is slightly more pronounced than the Konis, not a great deal but the Konis did corner fairly flat for such soft springs.
I then ran on full hard rebound all round, the ride was awful.
In all fairness the ride was never great on the Koni springs either, but the WIM springs i have are not suited to very hard shocks, the best way i can describe it is a bouncy castle made of rocks.
Very bouncy and crashy.
The next step is one turn from hard all round.
12 Days
Right, i had the dampers set up with one turn from hard all round for 5 days and the ride is good, much better than full hard but still not the smoothest ride i have experienced.
On good roads, (albeit not smooth tarmac) the ride is as good but any imperfections will be felt and on reflection the amount of body roll when making a brisk 75 degree turn is apparant to say the least, but on the other side of the coin the car has not suprised me once, where the konis had in the past (i imagine this may be due to the Konis being progressive though).
On a B road near work i was happy with the way the car performed, the road in question has a very smooth surface but has quite a few peaks and drops and some impressive camber, i felt confident enough to get up some speed and to my suprise i wasn't being thrown about (too much).
I am still happy with them, but now i have had them on a while i keep thinking how good the ride was on full soft and am starting to come to the conclusion they are very good for people who want to sit a bit lower on stock dampers but those wanting a more focused ride in terms of roll etc will feel the need for a big fat ARB (at this spring rate at least).
I have just set the dampers to one full turn from soft on the front and 1/2 turn from soft on the rear and will report back after i have used the setup across a few different types of road.
2 Weeks
One full turn from soft on the front and 1/2 turn from soft on the rear - A nice ride overall, but after playing about a fair bit this is the upper end of comfortable for a mix a different roads, the best setting is full soft all round imho.
True, it may not be the ultimate track day weapon, but if that is what you are after i would give these a miss as they will do a crap job unless body roll is your bag, if you want a comfortable ride (think slightly firmer than S package and a bit lower (with no rake) these are for you.
I see myself complimenting the Koni/WIM setup with a pair of bigger ARBs and in the nearer future Mk2 mounts on the front, but the proof is in the pudding and they will be staying on for a good while yet.
Update - 27.04.10
I am booked in with Tony at the end of the month to add some Mk2 Top mounts, so i keep an eye out and i will give my opinions on how the effect the ride and handling, could also be fairly useful for those wanting FCM mounts and not wanting to fork out £200 for them alone.
PROS
Lower
No arse in the air rake - Very good for Koni Sport dampers
Smooth
Predictable (due to the roll - Seriously though it is about the same as OEM)
Pre Stressed
CONS
More body roll than i expected from lowering springs
Not for track day weapons
Pricing is competitive, but it will have a lot of established competitors
Useless on high rebound settings
Smaller than Koni sport springs, but i have had no issues with noise *touch wood*
Again, any questions please ask.
1 - 20 of 24 Posts
Reads reasonably good so far. For various reasons i don't like a rake, even our MK3 coils have a zero rake.
With any lowering coils there is a uncontrollable factor that will determine results..... The dampers. If these are tired then performance will be impaired, don't forget the reason most change the coils is because their unhappy with the handling. Nevertheless it's our job to determine if the dampers are up to the job and in my teams opinion your are. Please keep us apprised of the performance.
Update added.
I'm no expert, but shouldn't you be running the front stiffer than the rear?
I've always kept the rear 1/2 a turn less than the fronts
I will run that, but i started with what i had with my konis originally and over time will have a play about and use the settings on the same mix of roads every day to give a fair comparison.
The only reason i didn't keep full hard rebound for long, was that it was so bad.
Just to add Tony mentioned he will be offering a small variety of different spring rates with these pre stressed coils.
Do you know what spring rates the Koni sports you didn't like were Andrew?
Koni don't give out spring rates but on miata.net there was a lot of talk about them being around stock, whether this means stock s package or what, i'm no sure.
My main issue with the Koni springs is that they sag and seem to like to rust up fairly quickly.
would have thought they would have been quite a bit stiffer than stock, being as they allow you to go so low, thats interesting.
By sag do you mean the ride height drops when you sit in the car, or they just lower with age?
Sagging is drooping and usually happens with age.
If i remember correctly the Konis are not short and hard, they are just a bit shorter than stock and the perches do most of the work, but i may be wrong.
Ahh ok that make sense. I thought it used these -35mm sport springs http://www.mx5parts.co.uk/product_info.php/products_id/1473 because it says in the full kit ad below that they use there sport springs, guess they mean some other ones?
http://www.mx5parts.co.uk/product_info.php/products_id/349
Ahh ok that make sense. I thought it used these -35mm sport springs http://www.mx5parts....roducts_id/1473 because it says in the full kit ad below that they use there sport springs, guess they mean some other ones?
No you're right, the Koni kit uses those springs.
Lowering springs are not generally hard, unless they are very short.
The "crap" eibachs are very soft ala 5 parts used on billies.
Update added.
Difficulty here is tuning the adjustable dampers to the static coil rates, to cover all we would need 30 different coil rates but saying that you seem to be doing a stunning job finding the perfect damper reaction...... Keep up the good work.
Update added at the top.
The lowering coils are designed for those with a desire to lower the car but not fit coilovers and to work with tired dampers. -30mm is well within most dampers "bump/ droop" range but there is an undisclosed tired damper window?
The actual mileage window is impossible to calculate because there's so many variations of dampers out there, i hit a wide window that encompasses most owners but it's not a perfect world.
All reads like a concerning challenge, well yes, but not at wim? We are not a "fire and forget" company, if the customer is not happy we deal with it, normally if you order some shoes and they don't fit that's your tough luck, we don't work like that.
Stiffer generally (but not always) means less grip, if you want understeer then yes front stiffer, if you like fun stiffen the rear (mine are fully stiff :) )
A lot is down to personal preference, have a play see what works for you.
I'm with Richy on this I have always run the fronts the same or stiffer than the rear.
Mostly because fronts affect feel and rears affect comfort.
Bear in mind we are both supercharged and the throttle can easily dial out understeer (not that I've ever felt that I have any)
I always ran my konis at full soft to 1/4 turn and that was with the very stiff FM springs.
On the track I ran them stiffer and once forgot to reset them before going home - the roads felt like I was driving on corrigated iron.
I got my settings/setup from Phil at P5 years ago when at the P5 sponsord Blyton trackday.
He told me to tweek the settings so that when you turn in the front and rear act together, not one following the other.
I found the front needs to be about 1/2 turn softer than the front to get this behaviour.
I thought you would need to run firmer than that to control firm springs like that?
1 - 20 of 24 Posts
