1 - 11 of 11 Posts
Offset stripes FTW!!!11
I've just test fitted some 5mm spacers with my 17" alloys and I can only get 4.5 full revolutions on the wheel nuts before torquing them up (probably another half turn but not tried that yet as the car is on the axle stands)
How many revolutions would be the minimum required?
Might I need longer studs? If so, where would be the best place to get them?
I think 6 is the recommended for any nut.
Pat...
Damn, beaten to it.
Pat...
the sva test wanted 6 full turns.
i'd say you're pushing the realms of safety factors at 4.5 turns. ok in an emergency but not for full time use.
tom
Bugger.
Any idea where I can pick up some longer studs (sounds like a
pick-up-line!)
Super Moderator
tom
Bugger.
pick-up-line!)
ask robsroadster or try dig out his thread on longer studs. i found some places for him to try but i'm not sure which place he went for.
probably worth knocking a stud out of a front and back hub to check the splines. they can be different dependent on year iirc
tom
Cheers, I've left a reply on the thread and have the details of mistertee and the place you suggested.
I've sent emails to them asking if they know the requirements, otherwise I'll have to knock the old ones out.
If I do have to knock them out, what and how am I measuring them?
We had a car at Timed Attack last year and due to a lack of communication and spacers it had the wheel nuts on four turns..... First lap a front wheel came off and it crashed..... Learn by my mistake, the nut needs to have the stud flush.
Discussion Starter · #10 ·
hahaha. now that's going the other way with safety factors!
a stud diameter's thread engagement is standard practice, or something iro 9 turns.
tom
Without the spacers the nuts don't sit flush as they are really long nuts. I get a good 9-10 turns though.
Just waiting for a reply from those two places now about the longer studs.
One thing I'll have to do is drop the car on the wheels with the spacers, let it settle a bit and make sure the wheels clear the arches, otherwise it'll be a waste of money getting the studs.
Discussion Starter · #11 ·
I got this reply from mistertee
12mm x 1.5 studs available in 47mm & 63mm lengths with a 13.1mm diameter spline, ?2.50 each plus P & P.
Are they the correct size?
Which length should I go for?
1 - 11 of 11 Posts
