What Wheel Offset Can I Get Away With On 1997 Mx5
884 Views 3 Replies 3 Participants Last post by  delcbr
alloys iam thinking of buying ar 15"x7" and offset of 15mm is that going to contact the wheel arch if i lower my car?if so what the max i can get away with any ideas?
1 - 4 of 4 Posts
You should just get away with 15 x 7 or 15 x 8 et15, it's considered to be around the limit before you have to roll the arches or add extra camber. You may have to pull the liners depending on how low you go!
if you go low enough for them to look good you will need to roll the arches
ok thanks think il lower it first before i start buying wheels with different offsets then take it from there.
1 - 4 of 4 Posts
