Not seen this anywhere on the forum......post up anything and everything (inc pics etc) from just a drive to fitting a supercharger and everything inbetween
New to the forum, been restoring a 93 Eunos Roadster for a few years now. Anyway today I finally changed the ashtray bulb. I was checking the gearshift boots were totalled as I suspected ready for a new upper and lower set to go in...soon. Also changed the gearstick plastic split leather boot for some real black leather which looks great contrasting the alloy Eunos silver gearstick surround.
Quite a bit the last few days, dropped the engine & gearbox, changed the speedo cable, changed the horns ( for older loud ones), touched up some surface rust, ordered some parts ...
Went in garage, checked tyre pressures, rolled car back a bit to avoid flat spotting, retreated back indoors, 4 degrees and too cold for shorts and flip flops.
New to the forum, been restoring my mk2.5 since September - build thread to follow ..... possibly.
Today I took my rear subframe for powder coating - £40.
Plans are full suspension overhaul - arms, bushes, drop links, wheel bearings, 270/276mm brake upgrade, Meister R suspension, uprated anti-roll bars etc. etc. (the list is never ending and I'm only at the rear so far - hope to start the front mid spring)
Once the car has been restored I'm venturing down the Rocketeer v6 kit.
Found some ice and went sideways round a corner, uphill. Over-corrected and narrowly missed going through a hedge but wrestled it back onto the road and made it home safe. No harm done. Bit more excitement than I was hoping for on my way home from Tesco
I took it out yesterday only to find the front left caliper was stuck after braking.
This morning I have taken the caliper apart cleaned the piston with emery tape in the lathe and re assembled it and bled the brakes, it now works again.
The caliper had rust pits so I have ordered a pair of pistons and seal kits.
As I have a replacement Me221 ECU due to messing up to previous one ( User Error Replaced under Warranty though ) I had to re load a base map so It is running badly at the moment its a lot lean at 25 to 30 Mph, so I will have a play to sort that bit of the map until it goes in for a rolling road mapping session in a couple of weeks time.
The other Eunos needs a new window switch as the left hand one has gone all floppy I will have to check it out before buying a new one though.
The airbox mould for my Danst gsxr ITBs is now almost finished. I just have to build it up with a few more layers of glass,
If you put more than three layers onto the gelcoat it will get too hot when it cures and distort or pre release.
I am looking forward to making a carbon airbox from the mould. ( its almost 20 years since I did any Carbon Fibre layup and 40 years since I first did any )
After a burst coolant hose above the alternator, my alternator got supercharged and produces 17volts at idle speeds.
I took the battery out of the car and discovered 2 more surprises, the negative battery terminal was broken in half (not a stock one, I use a brass one for less corrosion), also the battery ventilation was disconnected, which made the whole battery nest to rust.
Then I took out the alternator, and give him a good bath in a tub of gunk remover as it was nearly completely black.
After it dried out, I started the disassembly of it, in order to reach the voltage regulator and order parts for replacing it.
First photo is before it's bath, and then after....
Bought a new battery as I jumped the gel one too often and I think I ruined it. With an MOT due next week, better to just sort the issue. Plus I have a cut-off switch for Winter storage.
