Anyone with a walbro fuel pump that has log files of cranking?
I'm curious to know what voltage you read during cranking.
Mine is as follows:
Mine is as follows:
Because I don't know what else it could be. Do you have some suggestions?What makes you suspect the fuel pump is pulling the voltage down? Where are you logging your voltage?
ThanksThe starter motor will be drawing a damn sight more current than the fuel pump.
I'd try a known good battery as atlex suggests.
Speed is proportional to voltage in a DC motor so if you're seeing fuel issues, it might be related to the pump running at 3/4 speed, though cranking fuel flow shouldn't tax it compared to demand at WOT.
Thanks, I haven't actually checked them myself - but they were checked by the person that did my engine swap in July last year. Perhaps I should review, thanks for the suggestion.I think my cranking volts can get down into the 9's but 8.5 sounds kinda low. Have you checked the quality of the ground connections?
PS I do have a Walbro pump but it was provided with my supercharger kit long ago and I don't know if it's a 225 or 190.
Laboured cranking is likely voltage related, 'losing sync' could be related to microcontrollers in the ECU browning out from the low voltage.Thanks
Zero issues at wide open throttle, it's just this weird laboured cranking and sometimes losing sync. Fuelling is fine, my car is currently continuously priming on ignition and that also has no interruptions.
I have a new map to try today with different trigger edge settings as it was mentioned that sometimes "falling edge" can cause this behaviour.
My next port of call is either a new crank sensor or a new battery, I haven't decided which yet.
Based on what you've said, I have pretty much expected voltage drop then, thanks. I do think a stronger battery would help though.Mind you, if that was 10.5V measured at the battery it could still be a volt less when measured at the ECU, even if all the connections are good.
(I did a quick Google on expected voltage drop and found 125 - 150 amps seems to be typical for cranking a 4 cylinder engine. The ground cable is 16mm² and about 1.8m long, and at 125-150 amps it would drop over 0.5V from end to end. And that's only the ground cable; you'd drop voltage in the 12V cable too.)
That last line is important, no one seems to know but on the contrary, I haven't heard of anyone else having issues with an auto-converted car and there's plenty out there. Hell there's people making a business out of it.That rings a bell. On the original 1.6 the fuel pump relay isn't connected to the ECU. It's powered while cranking and then after that it's kept powered by a switch in the airflow meter (which stays on so long as there is some airflow). That's supposed to be a safety cutout so if the engine stops (in an accident or whatever) the fuel pump stops.
I don't know what complications being auto adds or what mods might be done to let you remove the AFM.
