61 - 80 of 99 Posts
Charged but not Prosecuted
Drafted a spec up a few days back!
Engine
Short nose 1.6
A/C Delete
Carbon Canister Delete
Washer tank moved to boot
48MM Ally Rad
B+N special upper cooling plate
Mocal 13 row oil cooler with braided lines and thermo plate.
K+N intake
Eaton M45 Supercharger running 7psi
TR Lane brackets and adjustable pullys and dual Throttle Bodies.
Jackson racing Adjustable fuel pressure regulator
Walbro 190lph fuel pump
245cc mk2.5 mx5 Injectors
Bipes Ignition controller
Fujitsubo 4-2-1 manifold heatwrapped.
MX5 Parts De-cat and stainless system.
Transmition
MK2.5 SVT 6 speed gearbox
1.8 RS ltd Torsen Diff with 4.3FD
F1 Racing stage 3 6 puck clutch
F1 Racing 4.1kg flywheel
Suspension
Mister R Zeta S coilovers
Energy suspension diff bushes
Energy suspension ARB bushes
Super Pro Wishbone Bushes all round
Performance 5 frame rails
Front and rear lower chassis braces
15" Enkie J speeds
195 50 Toyo R1R's pointed in the right direction by WIM
Brakes
Brembo disks
Braided Lines
Brembo adjustable Brake bias valve
Axxis pads front and rear.
Inside
Hard Dog X rear cage
Sparco sprint V bucket seats
Custom harness bar
Sabelt 2" 4 point harnesses
Staack oil and coolant temp gauges
Push start
OMP dished wheel
Quaiffe gear knob
Discussion Starter · #66 ·
Well the Supercharger and 6 speed box (I did the box while it was still NA) both made excellent impacts on the car but also hefty impacts on my bank balance :-/
I'd say the seats or steering wheel... odly enough, both made the driving experience of the car so much more exciting, you felt so much more control and feel.
Discussion Starter · #67 ·
Cave'd in and decided after 4 rag tops its about time I tried a hard top, and to my luck found one in the right colour on good ol' wightbay
Its a genuine Mazda one, even have the recipt from Northwood for £1150!
Its quite surprising how it firms everything up once fitted, actually looking forward to some rain so I can give it the true test!!
Also bought some Motorsport engine mounts, mine are pretty tiered being 20+ years old and these 40% stiffer ones should firm everything up nicely without to much NVH.
They are pretty boring looking things but the box they came in is rather sexual so here's a photo!
Discussion Starter · #69 ·
Got the Motorsport mounts on today, reasonably easy job.
It's proved to be a very worth while £65 spent, the front end of the car feels much tighter on turn-in, and gear change is much sweeter too, which was the main drive to do this so I'm very happy indeed!
Just Awaiting the charge cooler to arrive then to try and have it up and running for brands hatch!
Engine
Short nose 1.6
A/C Delete
48MM Ally Rad
K+N intake
Transmition
Suspension
15" Enkie J speeds
Brakes
Brembo disks
Braided Lines
Inside
Custom harness bar
Push start
OMP dished wheel
Quaiffe gear knob
Was this a description of your car up to date? If so, the Oil Cooler mounting photos shows your car as a LNC example. Although it was quoted so it may of been someone else's. Just wondering?
61 - 80 of 99 Posts
