1 - 10 of 10 Posts
"And the TrackDog said, let there be Boost.
Are you not fitting an intercooler Jamie? Remember that the outlet maybe in a slightly different position to the JRSC so a standard crossover pipe may not fit that well, may be wise to borrow one to do a test fit before buying.....
Barry
Barry,
As long as it's a metal variant, I plan to chop it in the middle to give some adjustment (much like the BRP one posted above). It's to help with the issue of the silicon pipes collapsing - no matter what adjustment I make it's still happening and noticed all other supercharger kits use metal bends.
I'll be going intercooled but only later in the year. My plan is to use a BBR intercooler I've got lying around with a civic alu radiator...
Jamie,
Ahh right
I was getting 'sucked in' silicone bends as well but completely closing the post charger TB at idle cured it
Barry
I have a theory that my problem is using the two different types of 1.8 throttles; they each have a different response so do not open at the same rate.
At the supercharger end:
At the inlet manifold end:
Thats not going to help the problem, looks like you cant change the pulleys over either
1 - 10 of 10 Posts
