I have a supercharged mk1 track car, my thread is still relatively up to date, link should be in my signature under this 👍
I'm getting bits and pieces together for a supercharger build on my 1.8 NA, are you running an intercooler? I have the chance to snag a chargecooler with a radiator and pump but not sure if its worth the extra complications over a simpler front mount set upSupercharged MK1 with VVT engine swap here. But I haven't done any track days since SC install![]()
I'm planning on doing track days but nothing in terms of competitions other than trying to be faster than my brother so not sure if going the chargecooler with an ice tank route will be worth it, chargecoolers do look like an interesting set up though.Yes I’m running an intercooler. At the amount of boost these run and the fact there is room to do a decent enough sized intercooler I’m not sure I’d go for the charge cooler. That said for the likes of sprints or auto tests you could run ice in the charge cooler and it’d be more worth while.
For normal track days and since you’re not lacking in space for a regular intercooler then it’s probably just unnecessary added complexity.I'm planning on doing track days but nothing in terms of competitions other than trying to be faster than my brother so not sure if going the chargecooler with an ice tank route will be worth it, chargecoolers do look like an interesting set up though.
