1 - 9 of 9 Posts
Afternoon chaps, some help with this would be really appreciated. Started this morning, was fine yesterday.
Symptoms:
Stuttering idle. Doesn't stall. Stays around 500rpm.
Big loss of power. At WOT it won't rev past 5000 easily
Petrol smell as if running rich
Cheers guys,
Toby
Discussion Starter · #2 ·
It also doesn't change idle when AC is turned on etc.
This is a common problem by the looks of the forum, and my old one did it too.
Unfortunately I'm yet to see a solution. Once it gets past 5000 does it behave as normal?
You can try resetting the base idle using the guides on the forum, after that have a look at replacing the coilpack.
Neither of these fixed mine though.
Went outside and had a fiddle today.
Booked in to go and see Skuzzle about this tomorrow anyway, so hopefully should get it sorted.
I found that poking the TPS seemed to make a difference? When I nudged the connector to the right the idle seemed to sort itself out, and then went back to stuttering when I let it go.
Sprayed a bit of WD40 over the connectors, doesn't seem to have made a difference. I've used a couple of cable ties but it's still intermittent.
Popped down to see Nick (Skuzzle) today.
It was the throttle position sensor!
Previous one was held together with a cable tie, and it was clear that the contact pins inside had been rubbing and causing the ECU to think all sorts of things.
It turns out that I had an underlying ECU fault as well, which required me to fit a new (used) ECU to solve the problem.
With regards to the TPS, it's well worth adjusting if you have the time/patience.
The way to do it is using a multimeter, and taking the sensor connector off, and using the probes to test the continuity between them at various positions.
There is a guide to do this somewhere (Miatanet I think)...
The TPS on the Mk1 1.6's is such a simple device, there isn't really much to go wrong, so I wouldn't necessarily bother replacing it. Adjustment is important though otherwise at partial throttle, the ECU can be told you are still idling....
1 - 9 of 9 Posts
