Hi, recently ish i had the ms3 mini tuned, and mostly is all good. I didnt leave the car there overnight so he guessed at the cold start tune. (he has a fair bit of mx5 tuning experience so i hoped his settings would be ok)
The cars a 99, ev14 injectors, new bosch battery.
Probably one in 3 starts im getting what i presume is starter kickback as the engine locks as its about to fire.
It takes a bit longer to start every time compared to the stock ecu.
If i could get the car to fire a bit earlier im pretty sure the kickback would be avoided, but i dont know how to do that unfortunately.
The cranking timing is already set to 0 degrees by the tuner, so i cant lower it anymore? I cant use negative figures?
The cranking rpm is set to 300.
Initially it would die after starting sometimes, but i added some fuel to afterstart enrichment and is all good now.
If i prime the fuel pump say 5 times before starting, then the engine fires sooner (same time as stock ecu used to) with no probs at all and no kickback. . - Any ideas why this would happen? Presumably its upping the fuel pressure a bit more from priming multiple times?
Any help appriciated as always 🙂
