1 - 17 of 17 Posts
Hi All,
Anyone looked into taking a lot (rather than a skim) off a 1.6 head?
Anyone any links or info?
Cheers,
Pat...
this is something i shall be doing shortly after the tb's go on for the first time.
Raises compression, but im not sure how much you can get away with.. will have to check with my cylinder head man
Waiting For The Summer
Unless you want to raise the compression, it might be worth seeing if it really needs a skim.
I took Halli's 18 year old head into work for them to skim it. It was measured first, and found to be 3 - 6 microns (thousandths of a millimetre) out over the whole of the head, so not worth doing
Lol - yes we really really want to raise the compression!
Pat...
there is a racing series that allow only stock cars. skimming does not matter though, and so large amounts are removed. Takes a 1.6 from 115bhp to 130bhp like the 1.8
Thats a cheap and easy 15bhp. You wont be able to run on rubbish fuel though.
the series... i forget. sorry!
50 is all we allow in one of the uk race series. I think a lot more is required though. Perhaps the dimensions and a calc is required to find a suitable skim for a realistic compression ratio.
You already know I'm sure, but skimming retards the valve timing, so you need to bear that in mind and take measures to correct it.
Malcolm
Discussion Starter · #15 ·
Nope - I know nothing at the moment so learning as I go.
What sort of measures?
Pat...
Discussion Starter · #17 ·
Okey dokey.
50 thou and some verniers for starters.
Anything else I need to know?
Pat...
1 - 17 of 17 Posts
