cheers guys,I've recently fully undersealed and rust proofed all of the underside of mine and to keep the sills clear to re paint them I used the rear crossmember of the rear subframe just in front of the ARB.
Once you jack it up by the diff you can just get two axle stands in side by side in the middle,might be worth a try if your chassis legs are damaged or corroded as well?
