So quick update for everyone else. Installation is being hammpered by incorrect or missing parts.
As I already found when I ordered it Kraken forgot to include a set of studs and washers with the manifold. He had no intention of correcting this when I raised it after ordering so I've had to order them (I had forgotten about this until recently). The same has been true for all the coolant and water lines hose clamps and crush washers, they're little parts but it's an unecessary PITA that I did actually pay for.
The coolant lines provided will not clear the coolant hose take offs on the thermostat. It looks like they might be reinforced fuel lines and there is no flex in them at all to allow them to clear the bead on the outlet. I've ordered a set of actual coolant line and it looks like they should fit.
The intercooler kit has been a shit in a number of ways:
- It fouls the PS lines so I've had to redo the cooler loop lines to clear.
- It also fouls the chassis legs both sides so I've had to add even more spacing to correct that otherwise it'd rub through.
- The BOV (which was missed in the kit because he was out of stock despite me having paid for it, and took forever to get a refund for as he didnt want to send out a replacement) fouls the AC fan and alternator pulley as it's just not positioned very well. It's a small Forge one so shouldnt really have been an issue.
- The throttle body coupler pretty badly fouls the rad hose meaning I'm going to have sort out some form of custom hose routing/setup.
- The coupler and cold side don't line up making trying to situate everything in a way that both clears and can be connected very challenging.
- It looks like the cold side hard pipe is about 2" shorter than it needs to be, even with the hardpipe pushed up against the ARB it still only sits into the silicone coupler off the throttlebody by about 1cm.
- The hot side hard pipe is 100% for a low mount kit and Kraken is showing no sign of sending a replacement. I've been chasing for it constantly now and I've had the usual number of excuses of "o i'll send it XX date" (despite not even asking for an address) followed by "O I forgot" and now just outright ignoring me.
Both myself and half a dozen other people have had similar experiences, and when looking online at youtube videos to see if I was doing something wrong with the fitment it seems like these are common complaints. There are a number of threads from the last few years over on the US forums which have a large number of people who have also experienced similar issues so I'm surprised nothing has been done to improve upon them.
Other problems atm also include not being happy with the straight threaded oil drain fitting so I've bought a tapered one which should secure and seal much better. I've also had to order a new wastegate actuator as they OE one on the 2860rs doesnt allow it to be clocked as needed. Actually positioning the turbo is extremely challenging without the intercooler piping to actually know how it's going to line up.
On the plus side I've sorted the gauge wiring that I can do out of the car, and ordered my ECU. I've goine for MS3 mini as they are well reviewed, well documented online, and given the public slagging matches between ME and customers on FB really don't want to risk any issues as it's not that much cheaper.
