Track car is ready for Donington on the 12th. I had to take it back to TotalMx5Repair as I had a number of issues with the Bofi clutch after it was installed. The clutch release bearing didn't even last the drive home after the install, and when we removed it this time it had clearly failed. We also found that my clutch judder was the result of glazing. This is very strange as it juddered immediately after install backing out the unit and just got progressively worse on what was a very gentle motorway drive home.
Mark was great as always, and the work was done to a top standard as most of you will know about. We replaced the bearing with a genuine mazda one and gave the clutch and flywheel a gentle scuff to remove some of the shine which seems to have helped. Reversing out the unit the improvement was immediately noticable and I had no issues on the way home. Lets hope that it stays that way.
Given the bearing failing has resulted in a significant additional cost to me (fuel for the additional trip to Wales, a days leave, replacement clutch release bearing, labour to replace the bearing, etc) I messaged Bofi about the issue and am very dissapointed in their reply. I was basically told they have never had any issues with the bearings in their own cars, and that they've never had a complaint about them before, and that was it. Effectively implied my bearing couldn't have failed, no appology or even acknowledgement that my experience of this bearing has been shitty, no desire to do anything about it. Given I've now spent a good few thousand with Bofi on injectors, turbo kits, turbos, M2 exhausts, 2 bofi clutches, etc I'm pretty annoyed and will source the other parts I need like the ME221, rollbar, (another) set of Ev14s, etc, from elsewhere.
