Engine mounts now fully installed and PPF alignment sorted. I did actually drain the gearbox and the diff to check they actually had fluid in them and was surprised to find they did (the box had 1.6L so likely not quite filled enough. There was a puddle on the floor at the shop when I went to collect the old exhaust which was apparently from my car where they'd forgotten something but I can't remember why, I think it was they'd forgotten to swap the rear seal). However, a load of the gearbox sensor wiring was left unsecured and the diff bushes have been installed upside down....... it's literally not even a joke now. So, to summarise all the issues and faults from the cars time at Unit 3 as I think I have gone over most things now:
-Incorrectly diagnosed water pump failure.
-Incorrectly diagnosed pulley delamination.
-Above were a loose crank pulley.
-Driving the car 30 miles to and from MOT with a loose pulley sheared bolts, damaging woodruff key, crank hub and crank shaft.
-Suspect incorrectly claimed loose crank bolt (car had done 7 years and near 40k miles on it so seems odd there'd be a problem just when they happen to have the car). No loctite applied to crank bolt as claimed along with claiming they torqued it up.
-ICV and cam sensor wiring hacked into as ICV had no power. No attempt to investigate/ resolve. Didn't solder joins, just wrapped wire around exposed cable and stuck tape over it despite claiming it had all been properly soldered. Solution to no power to ICV was a firmware update, took me 30 seconds.
-BOV fitting on IC pipe welded angled upwards so BOV contacts bonnet when engine is under load.
-Dual TBs changed and set incorrectly with precharger TB set as primary TB.
-Incorrectly diagnosed BOV interference with idle. Problem was actually TBs being unbalanced.
-Sent for MOT despite poor tune, knocking from crank pulley, no cat and ABS light on. Charged over £150 for the privilege.
-Momo Gear knob collar missing and not returned with the car.
-Invoiced for engine mount fitting which wasn't done. Argued that it must be something else mislabelled yet couldn't justify it.
-Centre console damaged where it has been forced shut on items.
-Claimed tyres out of round. Had them checked elsewhere and they are fine.
-Claimed incorrect LED side colours. Again, when checked elsewhere they are fine.
-Claimed tune is good with regard to idle, drivability etc, just isn't making the power it could. Incorrect, idles very badly and at 11 AFR and rest of tune means the car is undriveable.
-Exhaust V bands loose enough to undo by hand, as a result there was a massive exhaust leak
-Gearbox to PPF alignment incorrect
-Wideband harness moved and now rubbing on a number of things
-Gearbox sensor harnesses left loose and unsecured
-Differential bushes installed upside down
