561 - 580 of 633 Posts
Discussion Starter · #562 ·
More to come. Bit of traffic in the first half and I settle into more of a flow in the second. 12 oclock on the speedo is 80mph and I have the 3.9 rear end with the 4.1 speed sensor so actual speed is about 5mph higher than indicated.
  • Like
Reactions: Scotty Dugg
Discussion Starter · #563 ·
Just checked tyre wear. Nice and even across each tyre, rears are down to 5mm and fronts down to 4mm. Maybe the pushing I had was just due to asking so much of the fronts. I was able to push them enough to get too hot and a bit slippy.
Discussion Starter · #565 ·
Few pics
Wheel Tire Vehicle Sky Car
Tire Car Vehicle Sky Wheel
Wheel Car Vehicle Tire Hood
Vehicle Wheel Car Tire Sky
Wheel Car Vehicle Tire Sky
Discussion Starter · #566 ·
Discussion Starter · #567 ·
Discussion Starter · #568 ·
Discussion Starter · #569 ·
Bit cautious due to the damp
  • Like
Reactions: Zed.
Im loving your bonnet vents but couldnt find, or maybe missed, the details. Have you just cut and bent the bonnet to shape? If so that must have been very challenging to get so neat.
Ben
Discussion Starter · #571 ·
It wasn't that bad actually, you can largely follow the lines from the lower skin and then just a bit of sanding to neaten things out. Sanding the metal filler is what takes the time as it's pretty dense.
So you fillered the sides of the holes? Looks tidy from what I can see of it and probably won't let much rain in. What did you use to make such neat cuts without distorting the ali? You must have a massive worth bench - I cant imagine doing it without getting the bonnet dented and scratched.
Ben
Discussion Starter · #573 ·
Metal strip on the sides then filler top and bottom to support/shape it. It's only going to be put on for shows and track work in the dry so no worries about the weather. I did it using an angle grinder and on a garden bench with an old sofa cushion, lol. It was about £15 of materials to make, and about £30 of paint (I used 1k clear in the end as spraying that much 2k where I live now is rather risky.
Discussion Starter · #575 ·
Not too bad, hangs flat on the wall.
Discussion Starter · #576 ·
Got the car back from the tuner. Overall not entirely happy for the price, it was a lot of money for what was basically some pipe beading, a clutch, gearbox and diff bush fitting and half a tune. Total trailer costs were just shy of £500 too. I'll sum everything up fully once I've got the car back together as it's currently in bits for what I was told seemed like a failed water pump, I did think it was odd it wasn't leaking though but the noise did sound to be coming from there. It's due so I'm doing it anyway now but it turns out the problem was a far simpler one, one that should have been easily spotted, easily fixed, and wouldn't have required me having to trailer the car home with only a part tune. I duno how this was missed, apparently my crank bolt was loose and they torqued it up correctly so this should have been spotted then, especially as it has no undertray and would have been done from underneath otherwise all the charger stuff would have been removed which it wasn't. Just get the impression there was zero will to fault find at all. Will get it all back together and working the best I can and take it from there, I really want it done so I can crack on with the turbo build now.
Discussion Starter · #578 ·
Yeh, would be all it would have taken. And fit a new supercharger belt tightly then could have finished the mapping. Just couldn't be arsed could they.
  • Sad
Reactions: Zed.
Discussion Starter · #580 ·
All fitted and tight as I swapped the trigger wheel. Worked loose while there but still should have been obvious and easily sorted rather than just told there was a rattle and they wanted me to collect and fix it
  • Like
Reactions: Zed.
