Settings Ms2 For Mac Boost Solenoid Valve Bcs 35A-Aaa-Ddba-1Ba
6.5K views 5 replies 3 participants last post by  Niklas
Hello guys,
I have bought the MAC BCS 35A-AAA-DDBA-1BA for boostcontroll with my MS2.
Now I'm looking for the settings for this valve.
And then I mean the settings so the valve is controlled by the MS2.
Finetuning and setup will be done bij the tuner friday.
Can you giys help me with that?
#2 · (Edited by Moderator)
If it is the regular blue MAC-valve that most ppl run.
Slow frequency / 26hz
Boost control on
Temp threshold @ normal running temps or whatever you'd like
min duty 0
max duty 100
control interval 50 ms.
Boost control pin - the pin you are using connected to the valve.
Boost tables you need to tune yourself as this differs a lot.
Boost control on
min duty 0
max duty 100
Just curious but how did you arrive at 26hz?
Mine is different (Not much different though) and I just wondered. I don't want to confuse this thread with mine being different though. (OP - Having them set differently will make bad things happen, it won't)
