Gotcha! Funnily enough, we had that epiphany only a few days ago! Not too sure where to cut it on the door side yet since it has the inbuilt line that follows the door, I'm assuming we'd cut it right on the edge so the weld can be filledRepair panels (unless genuine OEM) aren't intended to be used as is. If you cut the front edge back to the face of the quarter panel, you'll be able to keep the original lines of the door shuts and save blowing the panel gaps.
10mm of filler in a corner susceptible to knocks is only going to end in disaster somewhere down the line. Steel adds value IMO, filler only adds risk and questions.
Thank you for the tips man!I'd only ever look to replace what gets you back to clean steel while making the welds blend well. The e coated original steel is better quality than the stuff replacement panels are made of, even though it is zinc coated.
I'd say always try keep the welds on the flat face of the panel or at least in areas with the least detail where you can get at them with a linishing wheel. Keep the original bends, swages and features wherever you can. The further you can stay away from the detail, the better chance you have of blending it all together.
Keeping original details like the panel overlap on the sill would be high on my priorities too. I use a bit of copper flat bar as a heatsink next to the edge to keep the joint crisp when butt jointing sill repair panels in to save having to try grind/file/chisel the edge back sharp.
^This.only ever look to replace what gets you back to clean steel while making the welds blend well
^^THISthe e coated original steel is better quality than the stuff replacement panels are made of, even though it is zinc coated.
yes & noI'd say always try keep the welds on the flat face of the panel or at least in areas with the least detail
^^ThisKeeping original details like the panel overlap on the sill would be high on my priorities too.
I use brass, bronze or gunmetal depending on whats available / closest, good as heatsink and also can be used behind panels to stop puddlewelds 'falling' through (if filling a screw-hole for example)I use a bit of copper flat bar as a heatsink
