1 - 7 of 7 Posts
Mr Miller :)
The thread title may sound a little simple but i am curious as to how to go about the following:
I ideally want to polybush the wishbones on my 5, but i want to know, what parts would be worth replacing, i.e balljoints, droplinks etc?
And also, ive noticed some people mentioning re-alignment, would this need to be done if i were to just swap the wishbones for polybushed 1s?
TIA
J
Oh, hai!
Definitely.
By rights, you should have the alignment checked every time you pull something off and put it back on again but that's often far more hassle and cost than it's worth. However, if you're doing something major (changing suspension parts, track rods, polybush, that sort of thing) then you should always have the alignment checked afterwards to ensure it's correct.
Mr Miller :)
Is it a job that could be done over a weekend? As I'd get another set of wishbones, polybush them and then just straight swap, as my 5 is my daily i ideally would need to do it over a weekend if this is possible?
1 - 7 of 7 Posts
