Removing Sensor In Cat
390 Views 5 Replies 4 Participants Last post by  TonyMX5
Hi,
My 1.6 '91 eunos has an additional sensor fitted to the cat in addition to the one on the manifold. I want to replace the cat with a by pass kit.
I have looked through the forums but I can find no mention of what to sdo with this sensor.
Should I just fit the bypass kit and then just tuck this sensr oyut of the way or will it affect the engine management system by not having it fitted?
Tony
1 - 6 of 6 Posts
It can safely be tied up out of the way no problem.
Remove it from the connector mounted close to where the cat sits and pop it in your toolbox.... ( weight saving
Thanks Guys.
I'm going to order a cat bypass pipe from MX5parts, unless there is a better place?
Tony
I have just fitted mine from mx5 parts, was a good price i thought. The cable to my cat sensor had just been cut and taped up by others
Phil and everyone else
Thanks, order placed today!
1 - 6 of 6 Posts
