1 - 3 of 3 Posts
I have used autoglym SRP in the past and it has always come up a treat, one trick is to place a board on the rear deck and cover with felt before laying the window onto it so you can apply more force when doing the outside as this tends to get more scratched up.
It also keeps the window flat so you are led likely to miss bits and helps prevent scratching and stretching which you would get if doing it directly on the rear deck.
For the inside try to persuade someone to hold the board onto the screen and polish away, hot work mind you
1 - 3 of 3 Posts
