1 - 16 of 16 Posts
Dan
Hi guys
Anyone got a pair of the little metal guides which the brake pads run in / follow on the rear calipers?
MOT is on Sat and I need to fit new pads and disks - upgrade from 1.6 to 1.8 so i need equivilent guides.
Anyone local near Blackpool / preston etc
cheers
Dan
I resorted to buying a set of rear pads from a main dealer when i needed some in a hurry (they come with OEM pads). I couldn't bring myself to pay that for a couple of clips, thought it made more sense to get the pads too.
Actually, i suspect the brakes would get through the MOT fine if you cleaned up the areas where they fit on the carrier brackets and put a couple of dabs of high temperature grease in the pad notches so the pads can move freely. I assume they are to provide a smooth rust free surface for the pads to move in and out. May be worth a try until you get hold of some, but on your head be it of course!
was b0builder
dan i def have 1 set think (enought for 1 side)i have 2 will have a look in about 30 mins
i got the sets to do a 1.8 upgrade but cant remember if i get 2 sets
You don't need them.
Never used them yet.
They're just anti squeal shims.
Pat...
-edit- Durrrr - misread - you mean those little finicky shiny shitty brackets. Nope - sorry mate.
was b0builder
just checked got 1 set
some dossy prat ordered everthing to do a 1.8 upgrade and only ordered 1 set of rear ones
you are welcome to one set if they are any good
Dan
Discussion Starter · #16 ·
Thanks guys.
The pads are just a bit loose in the carriers without the sliders / guides.
Bobuilder - I will take a set please.
I just need 2 x clips as ive already done one side already.
I will pm my address.
thanks
dan
1 - 16 of 16 Posts
