Guys, I use my 91 Eunos for Solos. Most times steering is OK but occasionally it bogs down/goes heavy at the wrong times. Saturday's demo at British Motor Show saw me heading towards the barriers more than once!
I understand its to do with the spring on the pump pressure relief valve allowing the relief valve to blow off under repeated hard turns/change of direction.
So the question is can I stretch the spring so it blows off later?
I'm told to stretch it to 40mm from what's likely to be 25mm (old age and hard use compressing it) - not taken it apart yet.
That then poses the question - if I stretch the spring am I likely to blow the seals in the rack?
Any thoughts/comments (polite ones only) gratefully received.
TIA.
TIA.
