Hi there,
I've got a 99 NB and recently switched to an ME221 as I've changed to car to run on ITBs. One of the challenges I had was around getting the alternator working with the new ECU. In the end I decided an NA alternator was the best approach and so bought a new one from ECP and wired in as per the well trodden method.
Fast forward to now and I'm getting a 0.2amp drain which appears to be coming directly from having the alternator plugged in via the two wires. Is this likely to be the alternator itself and a bad diode or more likely due to the wiring changes I've made?
