Coolant reroute is a good idea on the NA or NB (not the facelift NB though).
I have no experience with the Bofi kits, if it were the Kraken ones then I could guarantee it'd be missing a tonne of stuff XD, but I think Bofi are pretty good with it and I'd be surprised if there were any issues. They've always been super helpful if there have been issues.
Random things to note:
-You'll need injectors (likely in the kit)
-By body solinoid I assume you mean a boost solinoid, which is most likely going to be the 2 port, of which bofi have instructions here - MAC Boost Control Solenoid EBC For Mazda MX-5 | BOFI Racing it comes with everything you need, basically just a mount and the solinoid with fittings.
-You'll need a wideband with the ME221, and you'll need to go through wiring it in. There's actually quite a bit of faffing about with wiring for things like the EBC, wideband, other gauges you might have, IAT sensor, etc. My advise is do it right, heat shrink and tape things to prevent shorts, don't mess with OE wiring if you can help it and instead use add-a-fuses to take fused ignition power. The IAT, wideband, and EBC can all splice into where existing sensors where though so make it easier.
As an FYI I've been looking at the same kit as you recently and Bofi's prices have gone up quite a bit, I paid £50 for that solinoid just a few months ago for my gt2860rs based track car, and it can still be found for that online. I also don't think there's much of a discount for buying everything as a kit from them, it's more they just put all the parts in a "one click" to purchase place. Have a look about, I can guarantee you can shave a few hundred off the price by looking elsewhere. Also be aware Bofi orders can often be waiting on just one or two items to arrive with them before they send out the entire order, so thinking "at least i'm getting it all at one from one place" isn't always a good thing.
Lastly, don't pay the ridiculous £420 for one of their effectively Ebay TD04s. Yes it's new and being journal bearing should last a while but there's literally no point. I just picked up a genuine TD04L-13T for £70 with literally no play. Even if you get one with play you can buy a complete balanced CHRA to swap in for £120, so effectively a brand new TD04 for under £200. You can get that G19 manifold and downpipe £100 cheaper than they charge as well.
Any issues feel free to message me. My gt2860rs build is literally just ready to tune, first start and a perfect idle just yesterday so all my experience is still fresh in my mind. Will be swapping my M62 supercharged car to a TD04 G19 turbo kit soon.
- Make sure vac hoses can't rub on anything that might nic them, especially when passing through the firewall, and make sure they can't get kinked.
- Do not forget to pre-oil the turbo by dropping some oil into it and turning the blades a few times.
- Before first start remove the injector fuse and crank the engine until you see oil pressure on the gauge to ensure the turbo will get oil once when you do a first start (a feed line of air isnt great for it).
- Check for leaks around the oil lines after a first start.
- It is worth considering a 36-1 or 36-2 timing wheel to allow much greater timing resolution. This would be a lot safer on the engine. I actually have one for sale if you are interested, I bought a 36-1 but it turns out you can only use these on the mk1 and mk2, the VVT engine I have needs a 36-2 only to be able to retain the use of the VVT.
