Nose Pulley Tips
325 Views 5 Replies 4 Participants Last post by  PJB
I currently have the charger off the car and want change the nose pulley............whats the trick to get the pulley off....obviously its going to try and spin when i loosen it..........how tight are they is it best done on the car
1 - 6 of 6 Posts
Put an old belt on the pully.
Clamp it in a vice or with molegrips (on the end of the belt NOT the pully)
Job done.
BTW sometimes you need a good puller to remove the pully itself they can be a VERY tight fit.
Job done.
cheers Mark......i have a puller
you will struggle if its like mine!! grinder and a drill in the end, but it came off!! :)
molegrips, old belt, some brute force and jobs a good un.....about the only thing that went well today
1 - 6 of 6 Posts
