Hi so, picked up my turbo MK2 last Thursday and it drove great. Now it won't start and I have no spark...
A quick history of what happened:
I've had the plugs out and they don't seem to be flooded, tested them and no spark.
I'm going to order a new set of plugs and leads, what else can I check next?
I know there are a few sensors, crankshaft and cam, is that the next step?
There's quite a bit of PAS fluid everywhere due to the pipe coming off, could that have impacted something?
Before I picked up the car, the seller refitted the PAS system but did say the battery would need replacing as it seemed to be struggling to start in the cold. I've fitted a new battery since but it didn't start BEFORE the new battery either.
- Seen the car running a couple of weeks ago, drove fine no issues.
- Picked up on Thursday, PAS high-pressure pipe came off when pulling onto the driveway (it was recently refitted)
- Moved car across the road
- 2 hours later quickly turned the car around and went up and down the road to do so, parked up
- Next day, struggled to start but did eventually – only ran it for a few seconds before turning off
- 2 hours later, went to start and nothing apart from cranking
