Another little update, so despite saying I wasn't gonna turn the boost up until I changed the clutch, I instead turned the boost up and destroyed the clutch. It got the point where it was slipping in every gear as soon as boost came on so I had to change it earlier than planned. So I did a little shopping around and research and settled on an uprated dual friction clutch and single mass flywheel from RST performance. Now there was 2 choices when ordering the clutch, a 10 spline version for cars/gearboxes pre 2003 and a 22 spline version for post 2003. My engine is a 1999 engine so I assumed that the matching gearbox was the same, it wasn't. Evidently either the guy that sold me the engine sent me a different gearbox or it was changed in the past before the original car was broken for parts.
I ended up deciding to change gearbox as if I ever break one it will be much easier to find a replacement 10 spline gearbox than it will to find a 22 spline one. Changing the clutch and gearbox was pretty straight forward and it probably only took about 4 hours even doing it on my own. So the new clutch is a bit aggressive but its not dreadful although I'm glad its not my daily anymore. One issue I think I've found is that the original BMW clutch is one of the weird ones that self adjust to keep the engagement position the same throughout its life. This means that there is no adjustment on the clutch pedal/master, so now that I have a regular clutch with a BMW clutch master I have no adjustment in the pedal and its not great. I also noticed that my ghetto clutch pedal setup has bent slightly so It's time to replace it.
I could go down the route of installing a full pedal box but I know it's a ball ache to fit one in an MX5 and I just sold my spare pedal box a few months ago so I'm loathed to spend another £500 on a pedal box, I also don't really want to lose power assisted brakes. So Instead I decided to order a reverse swing top mount single OBP pedal (single pedal single cylinder). I had a look and took some measurements and I should be able to fit the clutch master under the dash if its forward facing, I already know that I'll need to modify the pedal to get around the steering column but other than that it should hopefully wok out nicely. My only concern at the moment is whether the remote reservoir sits high enough above the master, If not I can always use a super compact master with built in reservoir (yes it will be a nightmare to bleed but hey ho).
Stay tuned for more
Stay tuned for more
