OK so I figured it was time for an updated and more detailed To Do List:
Run new vacuum line with check valve to brake booster
Run new vacuum hose to boost gauge
Run new vacuum hose to ECU
Install Core4 Speeduino in OEM ECU housing
Wire BMW X60004 connector into existing Mazda wiring
Wire Mazda X16 connector into new BMW harness
Wire Mazda ECU connector 1 into new BMW harness
Wire SGI-100BT to generate speedometer signal
Wire SGI-100BT to correct Tachometer signal
Reinstall wiring for reverse light switch
Install new main ground wire from battery
Install new ground strap from engine to body
Thin out unrequired wires from Mazda fuse box side harness
Tighten Diff to Prop bolts
Tighten and check rear suspension bolts
Tighten and check front suspension bolts
Remove, Paint and reinstall shifter adapter plate
Wire rad fans
Wire Wideband sensor into ECU Aux pigtail
Tidy passenger footwell wiring and reinstall kick plate
Tidy under dash wiring and reinstall dead pedal
Fill and Bleed Brakes
Fill and Bleed Clutch
Tighten turbo oil feed (turbo side)
Tighten hose clamps on turbo water lines
Fill engine with oil and prime
Fill engine with coolant
Assemble and install driveshafts
Reinstall interior trim
Torque wheels
Roughly align wheels front and rear
Again I'm sure there are things missing so I'll add them as I find them.
Torque wheels
