1 - 3 of 3 Posts
Hello everyone,
Just bought myself a 94 supercharged Na bought it sight unseen 馃檲 it鈥檚 being delivered tomorrow at 馃 I currently own an MR2 turbo and 1JZGTE soarer and an MX5 has always been a bucket list car for me!
my new mx5 has been off the road for a few years but starts and drives well, passenger side footwell is a little damp so guessing I need to check the drains and there is very minimal rust.
Other then a service what should I Be looking at when putting it back on the road?
I鈥檒l be doing:
Oil and filter
Fuel filter
Diff oil
Gearbox oil
Discs and pads
Brake fluid flush
Coolant flush
any advice welcome!
thanks
Ben
brave but nothing ventured?馃槣
will await photo's, of the good & bad (theres always bad so don't be disheartened馃槈)
beware as the ecu lives under a false-floor panel in the footwell / bulkhead area below the dashboard, damp can cause electrical gremlins in the ecu & loomo_O
  • get the car up in the air, get to the rear of the car
  • check the sill end plates all over
  • the outer skin at the sill end
  • under the car where the sill faces the chassis rail
  • the arch lip all round
  • check all 8 suspension arms for rust, especially at the mounting points
  • check bush play in main suspension components
  • tyres
  • check how new the belts look, indication of how well/long the charger set up has been running
  • get a friend/SO to put a hose pipe over the car whilst you sit in side, check for leaks
  • with the soft top up, put your hand behind the shoulder belt area into the deck, check if there's a puddle
  • and finally, get a compression test if you get time :)
1 - 3 of 3 Posts
