New Fm Coilover Kit
829 Views 19 Replies 10 Participants Last post by  ric
Saw this posted yesterday over on miata.net and thought it might be of interest here for peeps...
http://www.flyinmiata.com/index.php?deptid=5635&parentid=0&stocknumber=13-16210%20%201990-97
1 - 20 of 20 Posts
Does this mean that those uber cheap raceland ones on eBay are worth a second look? Obvious question is what have fm done to them, and how do we do the same to the eBay stuff?
it reads as though they have changed the spring wieghts to ones better suited to the five
aye. next question: where can you get springs of a specific spring rate from? I'm a suspension noob but if it's possible for us to develop a Nutz special then I think we should go with it...!
Faulkner Springs would prob be your best bet, varying lengths, sizes and spring rates. I have bought from demon tweeks beofore but there site seems to be down at the moment. You may be able to go direct to Faulkner as well....
these aren't the same as the uber cheap raceland jobs are they?
these are around £450 on ebay, by the time you've sorted springs etc. you might as well have gone BC, GAZ or P5 etc.
I'm sure you could swap the springs on the cheap ones too but you'd have to buy lots of different springs to figure out which ones are best
The secondary springs are 112 lb/in, which gives them enough strength to overcome the damping of the shock and stay active. The primary rates are 391 lb/in in the front and 258 lb/in in the rear,
Just need to know the lengths and your away.... I'm sure the coilvers could be boughjt without springs if they are the same as teh ebay ones...
Why would anyone consider buying cheap coilovers and then start buying new springs on top of that.It defeats the idea of getting a good suspension set up cheap.By the time you've got them sorted you could well be into the price of a good set of the not so cheap coilovers.
These are the Racelands coilovers though, thats obvious.
Which, by the way, according to a Greek suspension-thing guy, are pretty easy to
revalve by opening and changing oils.
you're sure?
i can't see helper springs on the racelands that google immediately throws up.
best buy some cheap ebay one now whist they are still cheap!
you're sure?
i can't see helper springs on the racelands that google immediately throws up.[/quote]
Pic from my house. You really see any difference?
i do not.
I still have my doubts - Wee T is right in that it's probably not worth it. Decent springs will be 150ish, the helper springs aren't going to be much less I'm sure so even at 150 a set you're not saving a great deal over Konis etc and you don't get the damper adjustment.
anyone got any idea what the setup would cost from FM after shipping/import rape etc. ?
V-Maxx are very much different to Racelands. Different springs/internals/mounts. Much stiffer too.
Faulkner springs are about ?25 each depending on length and rate. Helpers are about half that....
you're sure?
Also the shock body is longer, suggesting it may contain more oil.The helper spring is longer, the main spring is shorter, it could just be the photograph of course,
The helper spring is at the bottom and the fm is on the top, unsure if it makes any difference to performance.
The one pictured sat on the cardboard looks like a rear damper....
True
True
Some reading from Miata.net:
http://forum.miata.net/vb/showthread.php?t=371583&highlight=v-maxx
the "eBay coilover" monster thread:
http://forum.miata.net/vb/showthread.php?t=289656&highlight=v-maxx
Going thru this stuff now...
1 - 20 of 20 Posts
