Hello,
Im helping my friend who bought NA 1.6/90HP (EU spec) with engine not running. We have both spent some time, found some problems but stuck a little - so help would be appreciated
So far we found/did:
- MAIN relay is not energized when ignition ON. Relay is ok, GND on coil is ok but no +12V on B/W wire, see attached picture
this leads to 15A fuse "engine" blown but no - fuse is ok, there is +12V on one side (L/F wire) in fuse compartment. So fault is probably after 15A fuse.
my 1st question - where is X10 connector?? cant find it
I was also looking for non original wiring - nothing suspicious near both fuse boxes or engine harness
- i tried to feed +12V to B/W wire near Main relay. Relay starts to work, fuel pump also runs (checked Circuit Opening / Fuel Pump relay in a meantime - ok). Fuel is present on Fuel rail (dont know pressure), injectors seem to get pulses. But engine does not start.
We got stuck in this situation, battery died, it became late so we left
my 2nd question - what now? why it is not starting? what to check?
Car is 50km from me so I would like to prepare for second attempt as good as possible
- car hasnt been driven much in general, has only around 60k km, dont know how long it was waiting being broken
- engine started for a while with some "Plak" (fuel spray, dont know how you call it) sprayed into intake. So engine seems to be mechanically more or less ok
- fuel pump was completely dead, whole assembly rusty etc. We have replaced whole assembly (from NB/NBFL cant remember), also added some fuel to tank. Fuel pump was still not working because next issue
