Na And Nb Flywheel Same For 1.6I
2K views 6 replies 3 participants last post by  8901
As title really, if I was to get a NA Flywheel,would it fit a NB (mk 2.5) 1.6 engine?
Many Thanks
#2 ·
I was told that the 1.6 NB flywheel and clutch was the same as the ones fitted to a 1.8 NB which on that basis makes it different to the 1.6 NA.
However
5 Parts sell one clutch for 1.6 Mk1/2/2.5 and a different one for 1.8 mk1/2/2.5 which makes it the same.
http://www.mx5parts.co.uk/clutch-disc-mk1225-p-857.html
I do need to know though as I have a 1.8 aftermarket clutch but a 1.6 NB, So I will keep watching this.
#3 · (Edited by Moderator)
I thought the clutch and flywheel were different, with the flywheel of a 1.8 being bigger and heavier. I know folk upgrade to the 1.8 but I dont plan to run more then standard power so the standard 1.6 would suffice for me. The engine code is the same for all 1/2/2.5 which make me assume it is the same for all 1.6's in terms of clutch and flywheel.
Just need to be 100% sure before I buy mind.
