1 - 17 of 17 Posts
Hi all just got an mk1 1.8 eunos from a family member for the winter as my s15 is just sketchy as hell in the winter weather.
Heres my 15
Currently running just under 350bhp and is my daily during the summer
This is the mx5 that i picked up the other day
Have already dropped it on coilies ;-)
Anyway hi and im sure il be annoying the hell out of everyone asking the same old mech questions but least i know what a lsd does so your safe from that one.
Discussion Starter · #2 ·
Finally got it moted and taxed today. Almost cost more that i paid for the car.
Hopefully will get the tyres swapped over to the other red wheels soon but shes on the road and mighty fun atm
New jack fits nicely in the back aswel
Welshy!
Welcome
Is that Richie Greco's old S15 by any chance?
Yeah it is. I got it off richie in may and have done a few bits here and there and love it to bits. The only reason im not driving it over winter is because my fiancee insists that its to dangerous where we live so her idea was to get another rwd soft top ???????
thats a lovely looking silvia. love the plate too. is it mechanically standard? a good friend of mine has just bought a forged engine and shizzle for his s15... Personally i thought it had enough power anyway haha!
the mx5s are real easy to slip out. back end comes out nice and easy
Welshy!
I thought so, Richie is a friend of mine
Engine Spec:
s15
SR20DET
T28R Garrett Turbo
F.M.I.C intercooler (unsure of make - imported with car from Japan)
Stainless intercooler piping
Japspeed cat back 3" exhaust
Japspeed de-cat pipe
Aluminium Radiator
Apexi Induction kit with all correct fittings
Iridium plugs
GTR fuel pump
Mines mapped ecu
Custom painted rocker cover
ABS removed
Braided oil and water lines
Stainless manifold (apex)
stainless turbo elbow (THS)
Slimline battery
Mocal 13 row oil cooler and thermostatic sandwich with takeoffs
Pigeon Mod
Sticker Bomber Carbon Kevlar Slam Panel (garage D Style)
Red slam panel and arch bolts
stainless intake pipe
Poly engine mounts
engine loom moved above arch for better clearence
z32 brake master cylinder
braided clutch line
Chassis and Drive Train:
Poly gearbox mount
Polybushed rear hubs
Solid alloy subframe bushes
Solid alloy diff bush kit
Full rose jointed Apex adjustable arms, consist of (toe, camber, tension and traction rods)
Cusco 2 way diff
HSD coilovers currently running 8kg/6kg spring rates
braided front and rear brake lines
front lower arms poly bushed
Machined track rod ends (modified with 6mm spacers for more lock)
front 20mm longer studs
Rota GTRs 9.5j et30 18s in neon green
Japspeed drilled and groved front disks
exedy clutch and exedy lightened flywheel
5 speed gearbox
25mm driftworks hubcentric spacers
25mm H&R hubcentric spacers
Z32 rear 2 pot brakes and discs fitted with r33 handbrake cables.
Interior:
FIA sparco carbon fibre bucket seat with super low rail
Nardi style suede steering wheel
Driftworks Hydraulic handbrake and Braided lines with wilwood cylinder
Blitz power meter id and SBC
Sard boost guage
sabelt FIA 6 pt hardness, mounting plates and eyebolts
Washer bottle relocated to battery tray (Apex slimline)
Jdm Crystal (dildo) gear knob
APex short shifter
Radio and stereo, iphone compatable.
Exterior:
Full Dmax body kit
40 front fenders
rear arches tubbed
30mm rear arches
Dmax rear boot lip
Fibreglass bootlid
Dmax rear lights
boot lock removed
That T28R must be fully maxed out at just under 350 bhp? On standard injectors too? I would have thought you'd need a 2871 turbo to achieve that kind of power.
cool looking car though, I've seen the s15 in the flesh.
1 - 17 of 17 Posts
