The FM Happy Meal includes a Flyin' Miata clutch and Flyin' Miata flywheel, pilot and release bearings. The Happy Meal will fit any 1990-05 Miata, including 1.6 engined cars.
The FM Level 1 clutch is rated for 318 lb-ft of torque at the crank, and is perfect for Stage 1 or Custom Spec kits with relatively stock engines. It's a real sweetheart, offering near-stock pedal pressure and smooth engagement, but it's strong enough to cope with anything stock engine internals can put out.
Used for less than 10k miles and as you can see in good condition, comes with all bolts, thrust bearing and clutch alignment tool.
Comes with original instructions and paperwork.
flyinmiata.com
Flyin' Miata clutch and a Flyin' Miata flywheel - a well-matched combination.
FM NA/NB clutch/flywheel Happy Meal
