Mazda Mx5 1.8 Nevada, for sale is my project track car due to a change in job I cannot use it as much as I would like. Its got approx 11months MOT and the advisories off the last have been repaired. It drives and sounds spot on all welding has been done recently work includes;
De powered steering, front completely poly bushed and camber set at 2 degrees,
New top and bottom ball joints both sides and track rod ends, new anti roll bar links front and rear, new pads and discs all round new caliper drivers front. 2nd hand high flow cat with middle box and a stainless back box. Rear arches are welded panels and inner and out sills have been repaired, front chassis rails have been replaced all has been undersealed. The rear subframe has been cleaned and wax oiled. The rear wish bones have been poly bushed and camber set at 1 degree, Roll cage has been fitted full service with new coil packs and plugs and a KN filter, I have the original flat boot lid and air filter box which will be included. It also has a new radiator and coolant. Brake fluid changed to dot4 high performance. And a limited Slip differential, just needs Paint work to finish it's basically an mx5 with no advisories which isn't heard of very often. That's pretty much track ready. It also has a new battery And a wrapped exhaust manifold. Any questions please ask or I have a video of it running if you message. Cash or bank transfer on Collection only please.
