Is there an easy way to see the timing mark on the bottom pulley?
I cant locate it at all
I spent a while with a peice of sandpaper on mine taking away deposits around the rim, then went in with a screwdriver "feeling" for the notch (as it was completely invisible as it had been filled with corrosion etc). This required turning over the engine a few times to gain access to the pulley, once I found it I blobbed it with tippex.Is there an easy way to see the timing mark on the bottom pulley?
I cant locate it at all![]()
dirty!I spent a while with a peice of sandpaper on mine taking away deposits around the rim, then went in with a screwdriver.
