1 - 6 of 6 Posts
as the title says, I've just done my first datalog run and loaded it into MLV for analysis. I then exported the .vex file into the fuel table 1 of MegaTune and it's reset my scales. KPa max was 230 and now it's 100. Likewise my RPM values have been changed.
Where did I go wrong?
was b0builder
why are you not using autotune on tuner studio
tunerstudio
tunerstudio
Because I didn't want to have to re-learn all the software just yet but if you think it's better than MegaTune I'll give it a go.
Where can I download a copy of the latest version (bug-free?)and do I just link up with the MSPnP and use it like MegaTune? Will my existing settings transfer across to TS?
You'll need to set-up the project configuration properties but it's no biggie.
Make sure you have the latest Java update installed and get on with it. It's alot more intuitive than MT and it has VE autotune which makes MLV interpretations a thing of the past. If you know MT, you'll know TS.
Download
Thanks Craigo. I've just done my first tuning run with TS Autotune and the car is running better already. Can I view the run on screen like I could in MLV? TS is asking me to load a .msl file but the system saved my run as a .msq file. How do I get around this?
You can datalog and analyse later. Go to datalogging and hit start in TS. Then open MLV and open the .msl file.
An MSQ is your MS 'map' so to speak.
1 - 6 of 6 Posts
