Mk2 Headlight Improvments ? Mk2.5 Any Better ?
17K views 18 replies 10 participants last post by  Mad Ax
Ok its not often i drive my mx at night, but the other night i had too and on a dark twisty country road, jeez i had forgotten how bad the headlights are until then!... ive got nightbreaker bulbs in (which ive not noticed to be any better than standard bulbs i took out) but lights are still terrible!....refelectors look ok just dont seem to light up the road....so wondering if anyone had found a good way to imporve the mk2 headlights ? maybe a projector upgrade or something ? or if mk2.5 headlights are much better ?
Been thinking about mk2.5 front end conversion for awhile but never go around to it, if the headlights work much better ( as well as look much better) it might make me get my finger out!
Anyone driven both mk2 and mk2.5 at night to compare headlights ?
Ian
I was using both dip and full beam and i think dip was actually better!.....i am spoiled by my other car which is a bmw and lights are very good even for non xenon but even so the light on mazda are dangerously bad....maybe i need some 100w bulbs popping in an dhope things dont melt!
Ian
I swapped bulbs for Nightbreaker+ a few weeks ago, and noticed a marked improvement over the Philips bulbs that were in there before. I know that you say you already have Nightbreakers, so not much help there I know.
TBH I've never had any complaints about the light capabilities on the Mk2, but maybe I'm in the minority.
#10 ·
There must of been something wrong with what came out lol....seriously i noticed little if any difference between stock bulbs and nightbreakers, i guess they are both rated at same wattage so i didnt expect much difference and i was right.
Depends where and how you use your car if headlights are upto job i guess and also what you get used to, mostly mine doesnt go out at night and if it does its usually main roads for mapping etc and thenn lights are ok, but get on some twisty back road and lack of visibilty at night slows you right down!
Ian
#7 · (Edited by Moderator)
What I find really weird about the Mk2 lights, (and I've been meaning to make a topic for a while) is that on dipped beam, you get nice coverage of the road directly in front of you, whereas full-beam that immediate coverage goes and it shifts much further up the road.
However, (on mine at least) if you pull the lever gently and get it in the position between dipped and full you seem to get both High beam and low beam at the same time (I don't know how that works as it's only 1 bulb?) and the light coverage is SO much better and usable. Where you have the increased light output of full beam however the low beam coverage of the road directly in front of you is also covered. But obviously the lever won't stay there - you have to hold it.
Has anyone else experienced this!? When it's in this position the light output is really good and usable.
EDIT: I'll get a picture tonight from inside the car.
#11 · (Edited by Moderator)
The Mk2.5 use a projector lense for dipped beam rather than a reflector in the MK2. This does result in a much more concentrated beam pattern, similar to that of an OEM HID pattern.
I understand the issue you have as I had a VAG car with factory HIDs prior to my Mk1, and jesus was that difficult to adapt to, was like holding a candle compared.
The MK2.5 conversion isn't cheap either. Let alone more complex than most make it out to be (connectors etc for the mk2.5 lights are different)
#13 ·
The were a little dull but its not long since i polished them up so decent enough now, i did find one of high beams wasnt working correctly which wasnt helping
still even with both working again now they are not great, will try some 100w bulbs when i get chance and have a play with alignment again see if i can improve it.
Ian
#16 ·
To be honest I don't know what bulbs are in mine at present, but my dipped beam is one of the brightest I've ever experienced. The main beam is useless to the point I never use it. I drive down unlit country lanes every night and see bang on just on dipped beam. My 330ci I use main and with my mondeo. Sounds like something's wrong with yours mate : (
#18 ·
Ok just to update this as ive been trying to sort it before the next sprint on saturday which we run at night!!.....polished up the lenses with solvol and got rid of cloudyness, not 100% perfect but pretty good, also fitted some 100/80w bulbs and checked all voltages and earths on bulb socket which were good, results........lights are better but still shit imo for high speed use!....will play around with adjustment some more now they are brigther but they just dont seem to throw the beam very well, high beam is only slightly better than dip is on my bmw!...and dip on the mx is truly dangerous on unlit backroads around here!
Ian
I'm having similar issues. I haven't checked my bulbs yet and I know the left-hand lens needs polishing, but on dip or main the lights are awful. My daily commute takes me down single-track lanes with overhanging trees, and when it's raining or damp the visibility is zero.
What also doesn't help is that the windscreen fitted by Autoglass last month seems to smeer like my wipers are made of slugs, when in fact the wipers are 6-month-old PIAAs ??? Can't work out why a new screen will smeer when the old one wouldn't.
I'm considering fitting driving lights for winter commutes.
