A few years back I built a DIY mk1 head complete with converted twin 40's as ITB's. I made 163bhp on a skimmed (42 thou) Piper 285h cams head with aforementioned carb itb's and a mazdaspeed exhaust manifold and MX5 parts system controlled by a MS2 Plug n Play ECU. Quite happy with myself.
However 1500 track only miles later and the bottom end rings are shot and my oil consumption is excessive......so rebuild time. ( I ran it too rich)
I have a VVT motor and originally was going to straight swap this in and add a ME221 ecu and proper jenveys as it is also now a road car. But put simply I do not want to start hacking around the wiring and or lopping off loom plugs to adapt the harness. It may still be an option, but probably plan b at this stage.
So my other cunning plan is to take my improved mk1 head and add this to the stock VVT bottom end. Gaining a bit of compression and a better oil pump in the process. So the questions are.....
Which gasket do I use?
How reliable is this?
Will any timing belt work?
Anything of note I should be aware of?
I realise retaining the whole VVt is an option, I am just looking for reliable advise as I do my research, as I suspect there is a specific gasket that is needed and I wonder if I am also building in other issues
