Mk 1 Headlights
623 views 4 replies 4 participants last post by  stuartp
Having an issue with my headlights, one of the bulbs was dim so have changed them both but its still dim and doesn't seem to change from high to low beam....any ideas on what the fault might be would be appreciated
Stuart
as above - it will be a bad earth
check the connector that attaches to the bulb - it might have melted/rusted and need replacing
if you do replace it, make sure it gets wrapped up well with something waterproof to stop water getting into it
Thanks for all the quick replies, it was the connector block/bad earth issue...managed to get it sorted by wrapping the spade on the bulb in tin foil to get a better contact...bodging I know but had to find a quick fix as its in for the mot on Monday and will hopefully do the trick until I can get a new connector block
Stuart
