Hi,
I’m about to start turboing my mk1 1.6 eunos and have read on the ME221 website that you can use one map for a high and low boost application,
using a 3 port boost control solenoid would I be able to run a switch in between the solenoid and input to the ecu so that the solenoid could be not used to manipulate boost pressure? And instead have the max boost determined by the internal waste-gate spring?
Any help would be appreciated
