1 - 9 of 9 Posts
Hi All
I am getting very close to having everything ready to install my M45 SC but now need to source or fabricate some sort of heat shield / blanket and was wondering what alternatives there are to the TDR Heat Shield Blanket which seems to be rather expensive for what it is ?
I was thinking of heat wrapping the manifold pipes then fabricating something using these to sit between the manifold and the charger :
http://www.ebay.co.uk/itm/HEAT-SHIELD-HEAT-BARRIER-G2-DOUBLE-MATERIAL-5-25mm-/310559535425?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item484eca7141
http://www.ebay.co.uk/itm/Heat-Shield-Aluminised-Material-Mat-Exhaust-500MM-X-1000MM-New-Rally-Race-/121037148662?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c2e6051f6
Total cost around £40
Would this work ?
Any other suggestions welcome please, what do you SC guys use ?
Many thanks,
Tim
Thanks Mexico - I have ordered some similar spec cloth, is it ok for it to have direct contact with the manifold or have you kept an airgap ?
1 - 9 of 9 Posts
